As above really. I'll be using it primarily for towing a grain trailer which I intend to chip into, possibly some hedge cutting and running the firewood processor. I was thinking perhaps 100hp as a minimum really (not sure where I arrived at this figure) and over not got the trailer yet, but will be borrowing a 10t one fit the time being.
I would also like a loader or front links.
What HP do you think I should be looking at?
Cheers
Mark
You will never get 10 ton of wood chip in trailer so you would get away with smaller tractor, old farmer once said to me you only start to worry when you get to bottom gear on a hill.
I'm not sure what weight of chip I'll get in the 10t trailer. But I guess it's better to have a few HP to spare😁😁
At best you will get 8 tonne of chip in a 10 tonne trailer so 100hp will be overkill. More important would be get a tractor with air that will actually handle well on the road and a trailer which has air brakes.
Thanks John. I'm staying to look at some options, then see what's about. Tbh I hadn't really given much thought to air brakes, given the nature of the work it'll be doing is a must.
I would look for 120hp
A johndeere 64-- is a very nice size tracto
Air brakes are not the be all and end all of braking
The width of the pads is important
Id rather tow with hydraulic brakes and 9 inch pads than air powered 4.5 inch pads
Also check that there is 2 brake pistons per axle as one is not enough
And most 40 kph tractors wont have air anyway
And small 50 kph tractors dont seem that common
The brakes on tractors supply a constant flow of oil to the trailer line so if you feel the need for for more braking force add more pistons although thats probally a better idea on 9 inch brakes only
120 hp will also power a 3 meter flail mower with ease and take a verge mower without falling over if you look at these in future
Thanks Sent, more food for thought. I've looked at a JD 6420 (I think iirc). Nice tractor, would be good to have some room for growth in the future.
Cheers
