Building a logging bridge
A pipe sized enough for the flow in the bottom & then fill the ditch with logs all in the same direction along the ditch. Tanks crossings are made this way using pipes.
:thumbup::thumbup::thumbup:
Just what I was going to say.
Depending where you are, Huws Gray should have suitable twinwall pipe in stock. You can cut it with a saw to length.
Chris
Interesting!
As you say a 'Pipe Fascine'
The outer pipes are connected together and the whole bundle rapped in netting.
Perhaps for a log fascine, cargo straps could be put around the bundle to stop any logs escaping sideways up the banks, on either side of the stream.
