Ride on mower won't cut long/damp grass
spandit
I'm not talking metre high pasture, the grass is, in places, about 8 inches long. I'm using a Snapper 33" 13hp rear engined ride on, with a newly sharpened blade, on the highest setting (actually one higher than that - you can latch it above the teeth) but every time I get grass wrapped around the ends of the blade and it just smokes the belt (which aren't cheap)
I'm wondering if fitting a shorter blade to give more tip clearance might be a solution or failing that, cutting the guard away to let the grass out (possibly not the safest solution).
Ideally, I'd keep the grass regularly mown but that hasn't happened and short of buying an Orec Rabbit (REALLY expensive), I'm getting fed up with stopping every few yards to remove the jammed grass from the blade ends
  • Replies 49
It is a collector mower but I've taken the collector off so it just shoots grass out the side (when it actually cuts). I'm just disappointed because with a big heavy blade and a pretty powerful engine, I thought it would be unstoppable but apparently not. I do have the old blade with chipped ends - might try cutting that down and trying it to see if it makes a difference
If doing so, be sure to measure an cut accurately or you could upset the balance of the blade, and result in vibration and damage to your mower. :thumbup1:
I was planning on measuring and then balancing the blade, grinding small bits off the heavy end until it's even. Mower vibrates a lot anyway... :D
