willcamper
Fixing Splits
Hi all. After some advice.
I have some 2" boards (elm) that have started to split while drying.
Once they have dried what is the best way to try and fix them?
I have seen a Dutchman joint video on youtube but not sure if this will work as they seemed to be doing it for decoration.
I have a pile of sapele off cuts and thought these would be a nice contrast.
Question is, would this joint with the use of several sash clamps knit the split together?
Any advice very welcome.
Share this post
Link to post
Thanks for that. I've just spent the last 2 hour watching youtube tutorials on bowtie and dutchman joints. They look nice and funky.
I'd go for it and post the pictures up here.
Share this post
Link to post
I did the same for well over an hour.
Do you think they go the full depth of the wood?
I'm just wondering if it would work if the wood was clamped tight before cutting out the shape in the board, then hammering in the bow tie shape.
Guess best to practise on a wrecked board first I suppose
Share this post
Link to post
The bowtie are to help it stop splitting any further, I usually go down between 1/2 & 3/4 of the way.
Share this post
Link to post
I've always waited until dry, but 90% of my timber is brought in air or kiln dried anyway. I've always used glue, the table above is my first time trying them.
Share this post
Link to post
I just experiment, I did find leaving them that bit thicker so they protrude from the table then sand down once glue was dry easier too.
I guess if the woods wet then it would shrink tighter around the bowtie , but also might push it out depending on shrinkage.
Share this post
Link to post
  • Tip site reviews
