It does look like a surface grinding machine wheel rather than an edge but the rpm of 1650 is high. That there is Heath Robinson at his peak :D
i've lifted it out of the box and it does have a recess the other side but both faces are fairly coarse yet the edge is relatively smooth? i've asked the seller how it is meant to be used so will have an answer soon but even if i mount it upright it won't be a problem if it's only going 200-300 rpm will it? i might even have it going slower.
the seller has just told me that it was for a surface grinding machine and was to be mounted vertically whilst the head moved back and forth to grind flat the metal held fast underneath.
Side mounted surface grinder then, so you should be ok to use it on your slow set up, before you use it though just to be safe do a "ring test" by holding it through the centre and gently tapping it with a file handle, if it rings like a bell its ok if it is more of a dull sound then it has some kind of flaw or worse a crack.
