Potato boxes, Firewood boxes. IBC's - PROS & CONS ?
arboriculturist
I am planning ahead and need to make a decision on which of the available containers works best for firewood before buying.
There are Pros & Cons for all of them of course, but one must come to the top of the heap.
Potato boxes are the least costly and readily available locally used - but the bases rot , they have to be modified to dry Firewood quickly and they don't hold exactly 2m3.
However the largest Firewood producer in the UK use them - but they do Kiln Dry everything.
Any views would be most welcome.
Edited by arboriculturist
  • Replies 56
I'm only small scale mate so just hand ball but if I had a forklift or loader it would be easy enough to cut one side out of the cage and attach it with some clips so you can hinge it once it's above your trailer etc and empty using the loader!
HI MATE thanks for that do anyone use fork lift rota thanks jon :thumbup:
