  • Replies 25
Technically illegal, unless you shoot the squirrels first, then it's legal!
I don't mind the furry little buggers now, quite like seeing their antics, so if feasible I'd try and make sure no one was at home before felling.
Grey Squirrels are classed as a pest/vermin species, their antics include bark striping, egg and hatchling raiding and passing 'Squirrel pox' onto our 'native Reds' almost wiping them out in the process but I'm sure you already know all this so as a shooter I'll take em out when ever I get the chance and one of the recognised/accepted methods used to flush em out of the drey is to poke it with some form of pole at which point they'll tear off through the tree tops at about 120mph leaving you free to chop said tree down !...:thumbup1:
Edited by TORNADOS7
one of the recognised/accepted methods used to flush em out of the drey is to poke it with some form of pole :
Not anymore - Drey poking then blasting with a shotgun (I'm assuming that's what you are suggesting here?) is now considered bad practice due to the amount of damage that occurs to the tree that you are trying to protect by taking out the squirrels.
You may of course be talking about a rapid shot air rifle or similar, so I would stand corrected in that case.
Very clever Mr. Bolam. I see your signature is accurate.
Obviously I am referring to the general practice of drey poking which is not considered an acceptable form of squirrel management anymore for the reasons stated.
