£10 an inch isn't a bad rate, might want to go a bit lower for soft wood. If access is an issue and you only have the option of unsing a small machine, you'll have to factor that into your time.
We hire stump grinder through Spectrum Plant, they have a good grinder range. We hired a bigger model for the week, used every hour of each day. went through hard and soft stumps no problem and only got charged for a couple of new teeth. Not sure if they are in South Wales yet though.
