excavator trolling tipper trailer forestry
segaiolo
hello, I'm new to the forum, having to carry out the work of restoration forestry, restoring roads, restoring stone walls restore stepped terraces, restore hillsides collapsed, transport stones and waste material, I was advised to use an excavator to which tow a trailer tipper instead of using two machines what you think is a good solution
you would have alternative solutions or machines due to suggest await suggestions
thanks guys, in fact it does not have to travel long distances, can be a good abinamento excavator with trailer, the web I found many small excavators with trailers, that weight can tow a midi excavator Takeuchi tb180 fr? if you have photos or videos that help you call to attach them as an example because the next
a final opinion if not too much to ask, what do you think of trailers towed by loaders, excavators matching trailer I had been recommended by a friend to pick up stones, he with hydraulic clamp and trailer towing us the spietra ground after plowing, I saw on the net that the backhoe use this system to match the shovel with the trailer I think the JCB and Lannen Multimate, what do you think of this solution for forest and landscape? Effective or slow and clumsy, who preferred solution, two machines for a dig and load and one for transporting and unloading '
