Just wondering what people think of the above blower, bought one the other day and its a fantastic tool! seems very well designed, the only small issue I have is sometimes when you try to give it throttle from idle it offers to die, so you have to slowly coax the throttle to let it build, any ideas what this would be?
Low or high speed adjustment??
Regards,
Garry
I agree carb settings, but i would say H jet set too lean, they are set up for the best emissions which means they are leaned off too much.
both mine were like that until they were run in, good bits of kit as long as you dont expect too much from them, any more than 30 minutes and im reaching for the back pack
Thanks folks,
I did think about the back pack but really this was the only offering with the vac function and I needed that for the mountains of dry leaves.
I will try backing out the high screw a little and see what happens.
Regards,
Garry
