T bar allen keys set
ally
I like T bars as they are small enough not to torque screws that much that the thread pops and also you can spin them which speeds up removal.
I have cheap ones with T27, 5mm & 6mm bits nad the long extension bits for cylinder removal and then a ratchet heavier duty one for final tightening of critical parts.
The ball ended Allen L keys are useful for carb and coil restricted access bolts where the ball end is invaluable.
are these the best for chainsaw work ? I've got the L shaped type rusting away in a plastic pouch with a few missing . Are the draper ones good or any other recommendations ?
Cheers
If you go down the Draper route,go for the Expert range.
I find they are a good compromise between quality and price,and available everywhere.
They also do a similar set of Tx drivers.
