Seen this before, I reckon the oiler pinion is incorrect. The 357 one has a flange on it on the internal bore that locates on a shoulder on the crank. This feature stops it contacting the crank seal unlike the 346 that has no flange but has a washer.
It is common for this flange to wear and this takes out the seal.
Make sure the pinion is the correct part as I reckon you have a 346 one!
'whale oil beef hooked', Spud may well be right there as i assumed the 346 and 357 oilers were identical !
  • Replies 31
Spud is right I think! As usual!
It looks like the worm gear is 5038921 which isn't for a 357 by the looks of it.
Doh! Stupid me!
:blushing:
Oh I give up, fit a washer and it will cure all the ills of the world, give world peace and make it work......not:sneaky2::lol:
If I send my 357 back could you fit a washer to it? Im worried it's not running right now...
Yes, it is expensive though.....£200 I believe:sneaky2:
I'll take 3...
Once I have some spare cash I'll get the357 retuned. It's truly bedded in but sometimes stalls on idle :)
I'll take 3...
If it is just a retune, it will be the cost of a crate of beer and the courier back.......can't be fairer than that:thumbup:
