mac 335 clutch - husky equivalent?
Arbtech Tree Services
Hi all,
Father in law has a McCulloch Mac 335 that has snapped it's clutch spring.
Have found an IPL that shows the clutch complete (£35) but nowhere can i find the spring on it's own. Guessing it'll be the same as a husky one somewhere so i've more of a chance of getting just the spring.
Six pin sprocket drum is 66mm o/d and 63mm i/d, spring looks to be approx 118mm in length.
Any thoughts please?
Regards,
Steve.
Hi all,
[ATTACH]182845[/ATTACH]
Regards,
Steve.
Looks like the same spring as a 50 or 51 Husky . Looks like not gosple . :001_smile:
Should have said be very carfull removing the clutch if you do not have the correct tool, the spider is made of a sintered material and will snap the legs off if you hit them, the tool is part no. 530031112
