My dealer still had to order one in,and that's the standard sized outer.
I imported some bar shortening,fuel tank piercing ,bad boys from Bailey's in the state's,but got stung for import tax.
know anybody with one? If so borrow it and take it to a fabricator. They'll cut you one out of a bit of sheet very quickly.
Or buy yourself a plasma cutter and a sheet of steel and make dogs to your hearts content.
I have the shorter hard wood dawgs on my 372 ( think they are the same ) . If you want to keep it like that you only need the outer one . You may find a used one on the bay . If you want the bigger soft wood dawgs then you will need the pair obviously .
