Does any1 use these bits of kit when sharpening??
All of my saws are stihl apart from my husky t540....will the roller work wrh this saw too?
Cheers team
Jamie
Just use a file gauge you big nancy!
If you had a 170, a 210,a 240 and a 660 you would need 4 different roller guides.
And the top plate angle would be set at 30 degrees,where as Husqvarna (and Oregon) recommend 25 degrees.
So it all depends on what saws and chains you have.
I hadn't come across these before lads so was jus after some advice, I didn't know you needed a different one for different saws sod that, I have a t540, ms310 and ms066, my sharpening skills are pretty good to be fair, il jus crack on as I am👍
Can't you just get the apprentice to sharpen your chains?
Our lads aren't even allowed to look at my chains without express permission :D
We have no apprentice yet Joseph...u should apply 😜😜😜😜
I agree my personal gear is my own n my own only....but the works gear gets hammered a lot so forever sharpening the feckers.
You couldn't afford me. Besides, I'm too pretty to be your bitch.
