Thanks Spud. I'm good at cleaning the saw and the air filter gets blown off. I mix my own fuel and confident it's correct.
I'll get the guy to check adjustment.
Thanks.
Good, it should be tached to 12500 -13000 against a max of 13500rpm:thumbup:
  • Replies 43
Hi Carpenter,
I will not be able to check Arb talk as I am doing shows in Scotland.
Please call me on 07568 108953 between 8:30 - 5:30 and give me all the details and I will try to help.
Kind regards
Eddie
Mine has suddenly started not reving up, just stalls it self?
Why?
Its all ways been on aspen
Any help appreciated
A couple of things to try - look unde the carb cover held on with one big screw, there is a gauze strainer under there, about the diameter of a pencil - check it is clear of woodchip.
The other thing it may be is a hole/split fuel line, they tend to split where they compress in to the fuel tank!
Other than that, the carb may need a strip and clean - try taking the H&L screws out and use one of those red pipes on a can of WD40 and get it down their screws before replacing.
Will try that thanks
Hi Carpenter,
Kind regards
Eddie
Thanks I will try what spud said
