My best was water sewage and electric all in one auger hole. All on private land I fixed sewage and water about £80 for electrician.
Hmm that was a lucky outcome to an unlucky situation!
Not sure how much mine will be, waiting for the bill, but 3 utlitly vans and 3 blokes were there for 3 hours fixing it so I doubt it will be in the hundreds anymore:thumbdown:
Never mind, will make me be a bit more careful in the future , but as we all know services can be found in the most unexpected places, I once went through a BT line right in out on the moor on Dartmoor- just a small one that connected 2 remote farms. what are the chances.
I would use 4"x4" posts,but bolt on a section of 4"x4" to the front of your post.This will get you 4" away from the haunching,but put your closeboard to the edge.
a cheap air compressor with a nail/staple gun speeds things up.
If on a school route concrete posts in early,as once mine were all pulled out of line at 4pm
just use fast set to prevent that or use a dry mix and tamper it down
