remember and wear a mask as carbide is bad for you. get green teeth as well they are so much easier to sharpen you can even stand and drink tea while your doing it far better system
What do you use to sharpen them with?
diamond wheel on a 6inch bench grinder fully enclosed to keep the dust in the enclosure has a thick layer of grease inside it you just scrape it out every now and then to clean it and fill it back up works great and keeps all the crap inside
