Hi all,
Need to sort out a quick change headstock for my loader and then some brackets to go on bucket and forks.
Can only seem to find euro 8 type head stocks on ebay and they are 290.00
Just wondering if there is anything else i've missed on there before i take the plunge?
cheers
Its a massey 30E
Its not like the mf80 loader.
Will most likely have to get a headstock, then get some pin brackets welded onto a plate to fit the loader then weld the plate to the head stock.
You many find it fit well with little changes as yours is what I call a proper loader, the euro 8 is one of the most common bracket used so easy to find buckets , tines, and forks with them already fitted.
Yup, going to re measure up tomorrow and go from there
I have euro 8 type on a quicke loader, having a standard interface is handy if you borrow or hire attachments at any point. The brackets are a bit overpriced for what they are. I made some once to fit. If you got a few pairs made by an fabricator might be a bit cheaper.
Do you still have the 3040?
