  • Replies 21
Hello.
I have a 2yr old 550xp. It's been starting ok when cold, but can't start it when warm.
Any ideas folks? Have any of you had similar problems?
Thanks
This is what works on my 560 ....ONE pump of primer . DON'T touch the red lever ( as ignition is always on ) . De comp in ( if you don't want to destroy the metal pins that engage with the stater mech ) Grab it between your thighs and pull sharpish . 2 of these pulls and it goes . Don't flood it ! :001_smile:
Thanks stubby.
Have tried that, and all sorts of combinations, but she won't go!
Typical. 5 days of Rhody clearance this week! Bah.
Back to dealer then . I think there are a whole host of modded parts to sort this problem . I don't have a 550 but maybe some of the others on here who do can advise mate . Good luck ! ( Oh for an old 242 ! ) :001_smile:
Ha. The spare saw I'm using is
........... A 242!! Whoop.
Fantastic little saw in their day ! On a 13" . Might bend you back a bit on that bar though . Least you got a saw ......:001_smile:
I just leave the decomp button alone when warm starts fine
Thing is , on a 560 anyway , I ended up bending the 2 metal pins that engage with the starter when not using the decomp ...
