If you're just starting out and you need business, equipment, tech or training support you're in the right place. If you've done it, made it, got a van load of oily t-shirts and have decided to give something back by sharing your knowledge or wisdom, then you're welcome too.
Question
Paul in the woods
I'm looking to buy a house that has a few acres of mature woodland attached, that's the good news.
However, along one side of the property there are several mature trees, beech and ash, that are part of an old hedgebank at the edge of the wood. At a rough calculation they are about 25m tall and are leaning over the road. They also lean over an electricity and telephone line and, most importantly, a neighbouring house.
The road is a very quite country land and the cables only go to the house I'm looking at so less of an issue.
I think I have several options that I'd like some advice with choosing which way to go.
1) Do as little as possible. However, if a tree falls and causes damage I assume I would be liable as the land owner? Would an insurance company be happy to pay out or would they expect roadside trees to be professional inspected? If so who by and how often?
2) Fell the trees. I do like trees and plant a fair few but I'm also realistic and the trees would make excellent firewood. The problem I have is if all the offending trees were felled I'd probably need a felling license based on my initial calcs and that would be a pain. One possible option would be to pollard to under the cable and fell at a later date.
3) Trim the trees and actively manage them. Although with electric cables running through I can't see this being an easy thing to do so I'd rather get the work done all at once.
4) I gather the power company will trim some of the trees. However, seeing some of their work they have only left a 5cm or so gap between the tree and the cable. Does anyone know if I can discuss the issue with the power company and will they be happy to trim the trees back further?
5) Any option I've missed?
Thanks!
14 answers to this question
Register a new accountSign in
