The easy way to measure % moisture lost; weigh them in... weigh them out
Without the % they start at does knowing they have lost X% help?
  • Replies 28
Why not just do what all the other guys with big kilns do and invest in a proper moister meter.
What does it matter what an ivc weighs if the wood is dry.
If you fill the ibc level when its dry there will be a 150mm gap where the wood dry outs and contracts
Hi MIKE YOU HIT the nail on the head there mike 😆😆😆thanks Jon 👍
:confused1: Are you saying use a moisture meter or measure the gap?? your post is unclear.
Its not about what it weighs, its about the change in weight :001_rolleyes:
Hi SKY use a good quality moisture meter well well well there's no need to way them thanks Jon
As do I John, but taking a log from each cage and waiting for it to cool, spitting and testing is time consuming (As I mentioned in my earlier posts)
This thread was simply asking if others had tried weighing as an alternative, nothing more, nothing less :001_smile:
Hi SKY I see your point if you had all ash cut to one size in IBC then oak then beech just work it out from meter then try and work back to weight thanks Jon
