  • Replies 28
Ok, how long are do u think
Don't know, thats why I'm thinking of getting a scale, I'm guessing different woods will loss timber at different rate and different areas of the kiln will be more efficient at shifting the water.
I'm hoping to build up a good idea of whats going on, without the need to get logs from the centre of each cage, cool them, split then and use moisture metre.
  • 8 months later...
Still experimenting with my kiln, getting good results, I was wondering about something like this to monitor the drying progress
PALLET TRUCK WEIGHT SCALE HAND MANUAL DOOSAN DELIVERED | eBay
I stack the IBC's two high in the kiln, I could weigh the each stack, calk the weight on the stack, then check the weight after a few days.
Any one done this or any one see any reason it would not work???
Did you get a pallet truck with scales?
Be interested if they were any good :001_smile:
No did not buy one.
I only use about half my container, drying 12cube each time. The water coming out of the logs condenses on the celling of the unused end of the container, I know the logs are try when the water stops condensing and I get dry celling between the partition and the water droplets.
My little forklift struggles to lift two cages of wet logs, it easily lifts the dry ones, so there is a significant weight loss.
