My 261 has a running problem on the overun.
Starts and runs fine , but on lifting off the throttle it comes down to a fast idle before tick over.
Sounds exactly the same as if low on fuel.
Have stopped using it and will take it back to the dealer , still under warranty .
Any ideas?
Any ideas?
Air leak somewhere ?
Cheers lads. Can give them some idea as to what it maybe incase they are numpties :what:
Any rubber parts such as inlet manifold, impulse line (your machine has it built in to the manifold), crank seals, decomp valve, cylinder loose, carb loose and any mating gasket surface in the crankcase.
Air leaks are genefally rare in newer machines, parts generally last 5-10 years before they start leaking unless someone has stuck a screwdriver through a manifold or there is a fault with the saws manufacturing.
We shall find out ,took it in today . They have a computer for it but I think they don't know how to use it !
That inspires you with confidence:001_rolleyes::lol:
I will take it off their hands for a fiver:sneaky2:
He also said a local tree surgeon plugged his Huskies in that he has had for three years and was really surprised to see they had only done around 50 hours cutting each ,.and twenty idling!
