Kranman Bison
Big J
  • Replies 31
Remember this:
Slow though for any forwarding distance; read the comments below the vid.
edit: you can put a 3t mini on a 14' 3500 kg 3-axle plant trailer so long as you fit EH brakes to the trailer; what my mate has done with his hilux. :thumbup:
I "understood" regardless of the over-run brakes being 3500kg weight limited, that 50mm ball hitchs were limited to 3500kg also?
Being vaguely aware of the possibility of towing up to 4500kg with some of the older Range Rovers, guessing with air brakes though, and being unsure re the hitch.(and prob poss to get >3500kg 50mm ball hitchs)
Cheers
M
