I've been meaning to service my tw150 for a few weeks and its been waiting. Just got round to doing it tonight.
I ordered some filters up via local motor factors with filter numbers matched with mahle numbers.
Fuel filter is ok but the oil filter is quite a bit smaller than the kubota one i fitted last time!
Does it matter about the capacity of the oil filter?
I asked what the oil filters went on and was told japanese motors like mitsubishi shoguns etc....
i'll try sort a pic out.
The thread looks to be the same and the o ring seal is the same its just a small filter!
the one fitted to my jensen is the same size as the kubota one removed off the tw....
hi, if it fits on properly and it`s just a difference in height and slightly less capacity then I`m sure it will be fine, I`ve had this before when buying filters, but don`t shoot me if I`m wrong :biggrin:
It'll work fine. If you're changing your oil at a sensible interval (100 hours) then if your filter blocks up in that time you've got serious problems elsewhere.
OC196 is a good filter for many small 3-cylinder applications.
Edit- just seen you've got an OC194. Must be pretty similar.
