whats the longest and best bar to run .325 chain
Longest I believe is 24", although if you used Stihl .325 chain, you could use a big, hard-nosed bar on an 880.
Best would be the hardest wearing bar.
Granberg is the only .325 ripping chain out there...
Best thing is as said file a micro chisel chain to 10 degrees.
:001_smile:
:001_smile:
I've got a spare full chisel chain - would that be ok? Or micro chisel better?
Also Rob I'm sure I've seen you write that you file the Granberg all at 10 degrees - if so then I'm assuming that it probably isn't any more time consuming to maintain than a standard chain...is this so?
:thumbup:
Ripping with a cross-cutting chain, is both slow going and hard going on the saw.
It's marginally slower, and the kerf is marginally wider. But I wouldn't bother filing down to 10° before using the chain for milling. Just reduce the angle to 10° as you sharpen. It honestly does not do that much difference.
But I would be happy to hear about some formal tests done with standard cross-cutting chains (filed at 30°) vs the same chain filed at 10°.
:thumbup:
Sometimes chisel chain can be overly aggressive - but this can depend on so many things ie. saw bar combo, wood you're cutting, size of wood you're cutting.
Just give it a go at 30 degrees and see how you go - if it works as morten said work the angle down in increments to 10 degrees.
If a lot of vibration then best to go to a micro chisel.
:001_smile:
  • 1 month later...
From personal opinion the ripping chain is a far better option. I have found when using standard chain it will leave very noticeable ridges on the wood which becomes more and more noticeable as the wood dries. So much so that I have been back to a customers to plane a fitted oak beam. The standard chain also dulls a lot quicker.
