That appears to be a hydraulic/electro hydraulic winch set up, as best I can tell.
cheers
M
This clip(of a larger Krpan admittedly), is def hyd/electro hyd, which gives the necessary inching, fine control & braking.
[ame]
[/ame] Edited by difflock
cheers
M
Guess they must have changed the design as that one is the same as mine but you did get one some time before me.
Yes, it was cheap(er) than a hydraulic winch, but only good for snatching logs out of a pile,
or bringing them near the splitter,
impossible to effect any fine control,
either freespooling or winching depending on the clutch modulation,
and even if I managed to balance the slip/drag equation,
it would only result in burning the small dry clutch out.
A hydraulic winch, however small, is an entirely different animal.
cheers
mth
cheers
mth
Mine is definitely not hydraulic. Yes it's bit rustic but not had any problems when letting it slip. I did billets with it for a couple of seasons. Think you are over complicating things :001_smile:
Right, here goes ! !
A wee EDIT
The bundle failed because I had not left a long enough tail on the strapping (see 2nd last photo) i.e. the cut end rather than tension induced failure.
So the strapping is strong enough.(bundle possibly about 300kg-350kg, being a tightly strapped 0.5m3 in volume of soaking wet Lodgepole.)
P.S.
The only permenant modification to the splitter is a 30mm hole to allow the wire rope through, the "L" shaped piece of 76mm tubing merely sits in place, held secure by the tension of the wire rope, a sweet arrangment I thought!:thumbup:
597674d427e8f_DSC00041hydraulicwireropepretensioner.jpg.c4c7124b0bf335d670bca9183fe19542.jpg
597674d429fce_DSC00042firstattemptatthebusinessendneedsmorework.jpg.c74e64078791f4da2f1ae13840701732.jpg
597674d42ba1a_DSC00043onlymodtosplittera30mmdiahole.jpg.de8f85ecd30b81276477e70b779c89a5.jpg
597674d42d48e_DSC00044wellIfiguredthatshouldworkanditdid.jpg.9a8f179a5911e47561e3d625c014fe0a.jpg
597674d42f054_DSC00045firstattempthadtobackoffduetowedgehookfailing.jpg.c91ee271b196879bdb050a8c31d9dcae.jpg
597674d430d64_DSC00046readyforliftingthemomentoftruth.jpg.dcdb03f9d2705456b5349c7125aa2f46.jpg
597674d433deb_DSC00048successfromthedriversseat.jpg.63ab5697a434bc64ce0cbaa5357f43c7.jpg
597674d437cbe_DSC00049buggerstrappingcuttoshortandeasedthroughthebuckle.jpg.0c52207b3c4d8e27e02a46dec03a0b62.jpg
597674d43adf4_DSC00051proofthestrappingdidnotfailsobetterleavelongertailsinfuture.jpg.ed8d10b0fe6c55808858b1acb7ec4ba1.jpg
597674d43dc43_DSC00047successdespitebeingunabletousethe17tonneavailableduetopoorhookandropecl.jpg.e7684f47b3b26d7abe7a5f8156e38abf.jpg
Edited by difflock
I wished to test the concept, and knew the hook on the splitting wedge was the weakest point being subject to the full 17 tonne force.
So I will order a proper wire rope wedge socket, and beef up my fabrication.
Also need to throw another couple of pallets below my wooden bundler frame so as to leave the pipe/wire rope at the right height.
But HEY! it WORKED!!
first time too.
Also I dont need the plastic tube(Ex bale wrap, and perfect for the job) as the bale spike will penetrate the bundle easy-peasy.
I may purchase a proper Euro 8 bale spike frame for peace of mind and indeed handiness, since that is my forklift frame I am using for the ad-hoc arrangment.
Time for Guinness ! !
Edited by difflock
Yes, possibly:001_tt2:
