It's possible that it's an aged Auricularia mesenterica - Tripe fungus.
Not definately though.
It's quite desicated.
I've seen it on dysfunctional stubs on Beech before.
Your shot would suggest it's a saprophyte.
Hi Guys
I consider that it could be Chondostereum purpureum (Silve Leaf) with aged blackened fruit bodies. If its a pinky colour when young then that is a good bet!!
The position (near the base of a Beech) and speading tiers of fruit bodies are also an indication...
What condition is the tree in?
Hi Guys
Sorry for the delay in replying, decided to go on hols as work was so quiet:sad:
The tree looks perfectly healthy with a huge fully leafed crown. The wound in the photo is almost at ground level and about 3 feet high.
I reckon it was either some machinery damage, or bonfire scorch from years ago.
Rgds...Al.
i have seen the same fungi on an old poor pruning cut roughly 12-15 foot up ! the tree appears to be in good condition at face value but when i climbed the tree i found several deep pockets of decay within the lower crown where the main scaffolds of the tree form , one of the pockets of decay extends down into the scaffold union by roughly 18 inches , so i feel a 20% reduction is in order , what are your thoughts ??
Sounds sensible enough if you want to reduce the lever-arm loads lower down the tree. Impossible to comment on whether it is right for that tree without photos though - can you get any?
i will get some from the ground and try to mark the areas of decay , thanks for responding mister tee:001_smile:
