Most older tractors ( Ford + MF at least) tend to have a pull out engine stop, tie a rope to it. Not immediate blade stop but pretty fast.
A
In this day and age with the firm in question suppose to be at the cutting edge and you need a rope to stop it how can this be right?
I personally think Posch is massively over priced for what it is. The machine have pretty small cutting diameters for the money.
Just my opinion.
Good to hear differing views.
What machine do you use and if you went for an upgrade from your present machine, what would you choose and why? Thanks
I run a Hakki Pilke 1x42.
Had it for three years, and do between 600-800 tonnes a year.
In all that time, the only thing that has gone wrong, recently, is a valve stuck, that's it.
I have never had any problems at all with the machine, and is still as good as the day I bought it.
If I were to upgrade, I would buy the 1x50, bigger cut, and the bigger the better in my opinion for hardwoods.
I cant rate this machine high enough.
I also have a Posch tilting saw, and its always got wee niggles, bits breaking off, bits bending or twisting. Pretty flimsy.
Same with the Posch Packfix, its not the machine I thought.
Again, pretty flimsy and expensive for parts.
What's the price of the pack fix system? Does anybody elsa make them
That's a lot of processing!
I agree, the packfix is not robust for the industry it was designed for.
Also when you factor in the machine cost, the time element, specific pallet size requirement and netting cost the whole system is very expensive compared with containerised alternative. Everything can look different in hindsight of course.
Palax now have a lever that disengages the belt drive if you get a log stuck, it only takes a split second to operate so saves 99% of the wear on your belts if you do have a problem!
HI LGW on a tractor like a MF35/135/165/168/175 AND most the old tractors YES thats best way i no to kill engine them tractors 40 plus year old:thumbup1: will you SEE a NEW tractor of today still working well at 40 years old no way you well not see it:lol: and the older tractor COST PEA NUTS to keep going as wel:thumbup:l LGW thanks jon :thumbup:
