Has anyone looked into simply putting a Hydraulic Motor onto the PTO for front use and power it through the spools.
Motors are available to fit straight onto the shaft, and I believe a couple of the Concrete Pan Mixer companies offer pretty powerful ones to allow the mixers to be used on telehandlers and loaders?
It may be a way to get the power and control in one go?
Eddie.
  • 2 months later...
  • Replies 22
I want to fit a winch to the front linkage of a Valtra n141, any suggestions as to what make or model would be suitable? bearing in mind the shafts running at 1000 rpm, and are there any additional dangers attached to winching operations using a winch attached to the front?
HI ALL if need 6/7ton winch i have fit unimog or tractor fits in seconds thanks jon :thumbup:
