  • Replies 79
Come on explain your system then
With this system forced cool air passes a heat exchanger that operates at around 2-300 degrees C and from there superheated air circulates through the timber.
Much higher operational temperature than a wet system.
They say they have never have one not pass?
They also said I could use one in a smoke controlled area just dont tell the council. Only problem is you need planning permission to get the RHI.
Even the single heater that past the test was exceptionally close to failing at 27.6 pm when the limit is 30 pm. It seems stupid to me that you can test a 175 kw plant and then assume that a 195kw and 295kw plant will also pass the test without actually testing them.
Edited by renewablejohn
Are u sure u need planning permission to get RHI?
Jon I no nothing about the RHI but no of two operations that don't have planning that they need and still get the RHI unless that's changed very recently
More fool them. Specifically says in the ofgem files that planning will not be checked at time of application but will be required when inspected. Suggest they get a retrospective planning application in ASAP and hope the inspectors dont pick them up on it when they come to inspect.
Will be ordering one in next few week and asked this and they said ofgem aren't interested in planning and u can dry wood in kiln before u put it in burner
