ms660 owners....
wisecobandit
Bingo yeah that's exactly the same as this one.
Now ive found the reason out. Stihl actually list 2 different brake levers for the ms660. It depends on what handlebar you have fitted.
Fitting the other brake handle sorts the issue out for us if you feel its an issue cost is £21 + vat from stihl.
JON
Its actually a new 660 ive almost built up from parts hence the issue of not realising there where 2 different brake handles fitted. Ones slightly straighter and higher than the other which is what I need.
Hi wise sorry I was thinking it was a new one mate sorry mate all the best with it mate thanks Jon
I have done two thinks to improve my 660. Firstly the factory dual port muffler & secondly the large output oiler. When you have run with both is makes a lot of sense.
Its already fitted with a dual port muffler and high output pump before its even fully built or had an ounze of fuel thru it :thumbup1:
Where's the best place to get these please? As they're stated as factory I'm guessing dealer, but is there an alternative?
Reason being I'm looking at running the Sugi 42" bar for milling/ringing and although the saw is great I wonder about the oiler output.
Kind regards,
Steve.
Kind regards,
Steve.
1122 640 3201 £33.41 + vat is the stihl part number for the 1.15mm oil pump
Dual port stihl cover is 1122 140 0800 but £39.64
Both available from l s engineers (google search it)
Hyway do a good dual port exhaust aftermarket job . "Stihl as good" does them on ebay for £24 with free delivery :sneaky2:
Many thanks for that.
Regards,
Steve.
