Vertical or horizontal ??
Andymacp
Vertical cause that's what I've got.
Make a decent size table then you can have a good amount of logs queuing up to get split saving on the machine running while you get another log on.
Also as mentioned, you just spin & shift the Logs around when splitting
Yes, a decent sized table of queing logs in the same height as the horizontal machine. Then falls the splitted logs direct to a logconveyor after the machine. So no Heavy lifting at all, and the splitted logs are placed on a stack a few meters away of your workingarea :-)
Here in Sweden Faxes Machines are very popular for this, see faxes.se
