550xpg
matt99
I can't seem to keep the chain properly tensioned every time I go to fuel up I have to adjust the chain tension then its really slack when I have to fuel up done a couple hours cutting from new its on a Oregon chain can't see its the chain stretching that much. It doesn't seem to be oiling that well can't see oil coming off the bar I've got the oiler turned up to max. What am I doing wrong?
All chain will "stretch" when getting hot, and brand has nothing to do with that stretch, as it is a natural and temporary result of the chain getting hot. It may help to turn the oiling up, and not over tightening the chain in the first place may also help.
Remember to remove any added tightening before setting the saw aside so it cools down. Worst case, failing to do so may result in a bent crankshaft.
The permanent stretch is a totally different matter, as it really is wear on rivets and in rivet holes.
