hi all,just looking for advice on what would be the best materials to run through a kindlet.i wont be doing logs so i would have to keep waste to a minimun
and also what saw would you recommend to prepare the materials to the correct size..:001_smile:
thanks
anthony
  • Replies 40
  wrights said:
Joinary off cuts I got lots and brilliant for kindling cut into 6 inch blocks the split with axe carnt afford kindlet just yet[
what saw do you use to cut them up to 6inch pieces :001_smile:
I've got 9 poplars I'm planning on felling in a family members garden,
Good access either through a set aside field or through the garden
roughly 20-30inch diameter if you're interested in buying the timber?
Read more
