Well if thats your set up at 21 matey your doing something right :thumbup:
I was thinking that. Fair play to you lad!
I have one of those extension blocks for the tow bar in the shed I think. Not sure it will make a grand amount of difference to be honest but if you want to try it then you're welcome to it if I can find it!
As far as chip flying out of the top goes, I'd roof it with expanded metal mesh. I just looked at prices for aluminium and it's about £50 per sheet, and I think you'd need two. So not a bank breaker by any means and a good long term fixed solution.:thumbup1:
  • Replies 21
A net over the chip box is your best and easiest solution. The air can pass out through it but the leaves stay inside.
It's also the lightest solution. A solid cover, even a tarpaulin, reduces your payload.
Sent from my iPhone using Arbtalk mobile app.
