How to reduce spread of roots?
smudge1
I have a job where the roots from an Oak are causing problems to the customers garage. In his email he suggested pruning the roots back which for obvious reasons im not going to advise.
What others ways could I solve the problem, I know pollarding may stop them spreading but its a large Oak and wouldn't really want to do that, would reducing it help....?
interesting :001_smile: I'm sure i was taught that pollarding a tree was a suitable means for reducing the spread of a root system, and that a lapse pollard can be dangerous for similar reasons....
still can't find any info to verify this though
Reducing and constraining are two different things. Small tree = low water uptake requirement = small root spread IF there is sufficient available water. Pollarding or topping a tree, I believe, reduces water uptake initially (lower transpiration levels due to less foliage) but an upsurge in latter years.
Spread of root system is probably due more to available moisture than canopy size - compare root systems of comparable trees on sandy /loam/clay soils.
