Looking for a bit of advice into the possibility of milling long boards using a workshop bandsaw. Got a project coming up that requires a decent amount ( enough to justify a new toy :001_rolleyes:) of floorboards/cladding/etc. The timber (windblow from around the farm) would be cut into 6in thick boards with an Alaskan and would all be green softwood. Ideally the boards would be 10ft long so would need to create a sizeable sled, etc. Was thinking a bandsaw would be quicker and more efficient than doing it all on an Alaskan? Budget of around £700. Pretty new to all this so any advice greatly appreciated :thumbup:
Bring the timber to me - I'm reasonably quick, but not at the expense of accuracy. I'm between Edinburgh and Livingston.
Jonathan
It is slow and very hard work using an upright bandsaw. And for 10' boards you're going to need at least 15' in front and behind the saw. If you are already setting up an Alaskan, you would be handling everything twice, and the time spent building tables/sledges would be better spent with the chainsaw mill.
The advice above is also more sensible than using a shop B/S, hire a woodmizer or take it somewhere (Big J) that is set up for it.
You would also be pushing your budget hard to get a B/S capable of doing much in a day cutting green timber. Remember you also need a very good extraction system on an upright B/S to extract wet dust, without which you'll quickly clag up your blades!
Ian
taking it to big j's is a good idea.
a workshop bandsaw is the wrong tool for the job really mate. if you are cutting it in to 6" slabs then you want to buy a rip saw.
try this one.
3 phase ripsaw | eBay
i do.
other than the lathe (which is modern) the two main machines are old and still in perfect working order...
a wilson 20" ripsaw and a whitehead 12x4" planer thicknesser.
