Stihl 450 Brushcutter Runs then dies after ten minutes
Essex arborist
undo the filler cap and don't refill refit cap and see if it starts and runs again
if it cuts out tank vent for sure
also check the fuel filter in the tanks not caught up and is out of the fuel when tank part empty
check it's on the bottom of the tank
I would guess at mesh screen in carb. Easy to clean, remove plate on carb that has single large screw and its underneath. Pick out with sharp screwdriver and blow gun clean. Refit so it seats well.What they usually do is suck fuel and muck against mesh and engine starves. Once it stops so does suction and muck drops off mesh.
