This mornings work stripping down a 300 tdi to find the cause of loss of power and a rather loud mettalic tapping sound...
This is the 3rd 300 tdi engine ive done now with the same issue. Also the reason i prefer chainsaws to vehicles. A bit of chainsaw oil,2 stroke and oily sawdust is so much easier to get off your hands than 10,000 mile old diesel engine oil :lol:
Anyhow basically the valve head broken off the stem.. If you look closly you can see the cone of the valve stem embedded still in the head.
And the piston damage! The valve head was broken in 2 embedded into the top of the piston. :001_rolleyes:
Edited by wisecobandit
  • Replies 64
Yes not good but this isn't just a landrover problem; worst one I've had was a customers Mercedes. When returning it to the company car owner the auto gearbox changed at the wrong time and on over rev pop went the valve head totally shagging the engine.:confused1::blushing:
Fortunately for me the car had been back to the main dealers a few months earlier for this fault so I was off the hook............... PHEW!
I wouldn't say thats a landrover problem, seems to me a low maintenance problem. the 300tdis are pretty good engines on the whole.
We own a landy and an isuzu, a navara before that. They have all had their own problems, the isuzu is the new d-max, but has had minor problems already.
Each to their own, land rovers are cheaper and easier to fix, japanese you need to plug them in before you get close to fixing. Then parts are expensive generally.
Overriding all that, regular maintenance and having some mechanical sympathy should prevent a heap of problems anyway.
HI WISE how have you done engines like that are they stander engines or turbo and pump open up as i have a mate drives the hard and say there good engines thanks jon
when i got the insurance payout from my l200 being written off I decided to put half the money away for something else and bought a 100k mile disco, mainly just for trailer/grunt work, 48k latter and have never regretted it. cost me no more in maint than any other big 4x4 I've had................so far.
