yes you can cut your own line, up to 3mm round i think.
fits most strimmers, comes with lots of different sized washers, to fit.
if unsure pm jonesie, he will sort you out
If you are talking about the Oregon Jet fit it will easily take 4.00mm , as in my picture . If you aren't sorry :001_smile:
4.00mm square in the picture . Had mine over 10 years now . Forget about replacing the plastic cone when it flies off . I bought about 6 or 7 when I gave up . I just use the 4 way head ( because it has a deeper recess for the nut ) but only use 2 lines in the lower fitting .
Edited by Stubby
is it, have not tried 4mm in mine.
Sorry if I am late on this but I have recently bought a 4 way portek head that has a aluminium dome on the bottom. Might be worth a look.
With 4 mm square it will cut down small trees. Far superior to the 3mm round I have been using
