Has been a very busy 2 weeks, in at the deep end but probably learn the ropes quicker that way (helps having a humphries lurking about in a forum to pester with questions 😊). There's been a bit of a change around which should hopefully mean I'll be able to input on potential improvements. Colleagues all seem sound too, missing the climbing tho...Thanks for asking, hope all good your end too!
Sent from my SM-N9005 using Arbtalk mobile app
  • Replies 31
Thought I would add this one - the FB is quite hard, to the point where you get a solid sound if you rap the top with your knuckles. There is another one, slightly smaller but looks the same, on the other side. Tree is pushing 4' DBH.
Alec
I think your set is likely to be Ganoderma sp Alec
There appears to be cocoa brown spore associated with the lower fruitbodies.
I. dryadeus has a whiter spore colour.
This at work? looks like one of your old estate trees.
Yes David, it's just down from the enormous plane, right next to the equivalent building at the other end.
Any thoughts on a prognosis, being as our place is a bit digital (ie leave alone/fell)?
Alec
Looks to be leaning away from the building Alec.
I'd be inclined to leave it in terms of target management but for its own sake and future stability, it may be worth considering a reduction of the sail and possibly the end weight of the larger heaviest lateral branches depending on assessment.
agree, Oaks seem to cope well with Ganodermas bar resinaceum, which this clearly isnt.:thumbup1:
Thanks David & Tony, I will mention it to the relevant people then at some point out of courtesy, but try to avoid panicking them into an excessive response.
Cheers
Alec
This one? how's it doing now Alec?
Couple of summers ago I thought it was looking a bit sparse in the outer canopy,
and retaining a couple of branches that may have been massaria.
That's the one - it is looking way better this year. I'll take a picture tomorrow but the canopy is now full and the tree looks good. We have a new facilities manager who is more likely to take up some of your comment.
Alec
