Logs as bbq fuel
forestgough
Hi Alex we run a large webber gas but would like a wood would your webber one run wood and what one have you got and size of logs to use thanks Jon
To be honest I've never tried using wood in my Webber but there's no reason why not. As above, you'd have to wait for the wood to burn down to embers and then you're basically running on lumpwood charcoal.
The only trouble is if you need to top up mid cook then you are back to square one whereas if you dump a bit of lumpwood on you are cooking again much quicker.
I burn wood in my chiminea for heat (like a patio heater) then when it reduces down to a nice ember pile I can take the chimney off and stick a grill on and cook. If you were running purely on wood then it would take a bit more planning to let it burn down but I suppose you could stack the Webber right up to begin with and then control the burn using the vents....
Hi Alex what webber have you got mate thanks Jon
