Haha cheers Jon. I'll try and remember when I get it out working. I'm looking for a workshop manual for it if anyone can point me in the right direction or may have one lying Around gathering dust! All the glass is there but the door frames are pretty rotten! I'll be putting my igland 55 on the back. Does anyone know if your able to to get a Front PUH for this tractor. Thanks for the help in advance.
  • Replies 109
HI HIGGS you after front pick up hitch are what are you thinking of doing then as it will be hard to your 55 igland off it there are mf breakers around HOWARD TRACTORS try them you can get book off your MF DEALER ON THE OLD PART 10 PARTS i was thinking of a front linkage on my old 290 but did not do does the muiti power work ok thanks try ebay to for a manual thanks jon :thumbup:
I was thinking mainly for carrying the winch to site if I had a trailer on the back. Then also possibly a weight block or blade. Just thought it would be a useful addition if I could find one. I'll have a search online for the user manual. The gearbox is good and tight Jon, no funny noises and it slots in easy. Going to change all the oils and give it a good service. It's currently in the local dealers having the front hub rebushed where the hole had elongated! It's got less than 3000hrs on it. Top of the list is a new seat though, I thought my arse was going to fall off after I picked it up lol.
HI HIGGS some times ive seen front linkage on ebay and try howards tractors we had the same on the mf399 now i have winch on the weight frame your tractor has LOW HRS TOO:thumbup1: thanks mate jon :thumbup:
Will do Jon, how did you get it to fit on to the weight frame? What kind of weight can I expect to tow with this tractor? The engine runs sweet and has plenty of power.
Will do Jon, how did you get it to fit on to the weight frame? What kind of weight can I expect to tow with this tractor? The engine runs sweet and has plenty of power. I'll post some pics soon.
HI HIGGS it will tow 6ton ok with trailer breaks we fitted winch to the front of tractor used the weight frame tow pin so the winch can off at any time i have some tractor weights for your tractor all so we put water in the rear tyres that was good in fields more grip thanks jon :thumbup:
