How much does it cost in the U.K for an oil change on a Kubota engine Quadchip plus diesel filter?
Just would like to compare with prices here in France.
Regards
Ty
  • Replies 39
I do my own on my TW150 VTR, couple of filter and some oil, £30 maybe.
  • 1 month later...
Is that £30 inc vat?
5Ltrs of good quality engine oil is going to be over £20
Then if your doing the job right first time!!
Are we just changing the oil here or an engine service
Engine oil filter
fuel filter (maybe a spin on or a replacement element filter)
Inline pre-fuel pump filter
air filter
Somethings which are often over looked especially by DIYers
Fan belt tension
Coolant level inc anti freeze %
check radiator core for blockage/clean
When having your chipper stump grinder or what ever serviced at your local dealer even on just a engine service they would/should give the whole machine a once over, grease all points (we do and we carry out a curious steam clean and surface paintwork polish) and advise on any items damaged worn or in need of some attention these are the things which a trained eye of experience would pick up.
These are points which are over looked when weighing up do i just undo a sump plug change a filter and bung some oil back in service done!!!!
Thats my rant over for the day!!
As a guide (don't know the engine in yours) I pulled the last Kubota invoice (1st July 2014) :
Fuel Filter £8.49 ea
Oil filter £7.15
Air filter £ £25.62
Genuine Parts + VAT
Labour rates at a workshop vary hugely from the rich south to the poor north! I've heard of rates as low as £45 to about £75!
Some years ago, I ran a FreeLander for the GreenMech towtug and the rate then was £75 or if had been a Disco or RR, £105 per hour! Back then, the oil was £7 per litre too!!!
They charge £140 an hour now for a 17 year old apprentice that forgets to actually put any oil back in the gearbox.
(Mountain man)
I was merely highlighting that first the price you pay a dealer to do the oil change service is not just for removing the sump plug and fitting some filters
Secondly the filters as stated earlier come to £41.26 that's before any labour cost incurred
Thirdly a dealer should know and stock the correct grade/type of oil filters and follow the correct practice in fitting/installing these service parts
So your not just paying some over charged labour costs
There's two sides to most things!!
Is it a chipper, is it a mower or another broken stump grinder who cares we'll fix it!
