Time to change the bearings on the Rayco , Not nice its all packed with mud and crud. I have been putting it off but its now got to be done, everything on it weighs a ton:thumbdown:
Bob
  • Replies 32
Where do you get these bohemith machines??:confused1::laugh1:
You've got to show us that thing in action:thumbup1:
Nothing fancy about it Stephen its just a brute:thumbup1: It goes behind the mog or telehandler. Its out on monday doing a stump about 8 feet in diameter thats nearly 2` out of the ground and I very much doubt if I will be there an hour.I will try and take a snap of it working.
Bob
http://arbtalk.co.uk/forum/attachment.php?attachmentid=157790&stc=1&d=1401483789
on grinder with that much power does sharp teeth make a difference or does it just smash its way thru anyhow?
Its a bit like that, as long as there is a tooth of sorts on there it will tear up anything. Its direct drive and has a Deutz lorry engine on so it never tires. A typical 2` diameter hardwood stump is gone in about 2 minutes, conifer and the like is seconds. But its massive so no good in a back garden, the lower deck of the truck is 30` long so telehandler and grinder combo must be about 35`.
Bob
And where would you buy such a thing?
According to Rayco there are only two in the whole of europe, they do however keep all the spares for it on the shelf.
Bob
Please find time to make a video of it in action!!:thumbup1:
I will if someone could explain how to convert vid on I pad to facetube:confused1:
Bob
