I've been asked to quote for removing a privet hedge including the roots. I remember seeing a video of someone using an engine hoist to lift them straight out without even having to dig.
Anyone tried this?
Mattocks are really good for doing roots. Maybe an old silky too. I usually dig round with grubbing mattock then cut roots with the ax end of mattock, leave enough stump to use as leverage an your away.
used my high lift for getting roots out, if you have an anchor point even better as you can use it like a winch,cut any stubborn roots off with old axe/grub axe, job done
turfor and some strops will do it,ive pulled apple trees out with mine.
just done a leylandi hedge no probs had some root 3 inch thick.
also use a ripper blade on a disc cutter to cut any large roots that wont pull out.
