Just bought a compressor for workshop. But would like to run a air nailer instead of relying on my paslode for fencing. Its got a 50litre tank runs at 8bar and 412l/m. Will it man a coil nailer firing 2.1 x 50mm nails. And if so any recommendations would help. Iv been looking all night and getting no where
Should do. I used to run one of those framing nailers that go up to 90mm off a 50l V twin compressor with no bother.
If you've not already got the nailer, I've still got my old one here and it'll be cheap :thumbup1: It's the one that takes the strips of nails rather than a coil one but it will go down to something like 40 or 50mm
Sounds good to me chris are they basically same nails as a paslode.
you will just want to turn down your air as low it will go to get a nail in, or you may risk burning out your compressor ( if it a cheaper end one)
my dad runs one of these Stanley Bostitch RC-10-U 10Ltr Roll Cage Air Compressor 240V | Air Compressor | Screwfix.com which is designed to run all day and will run most size nailer's and will also run of a small genny or I've even had it running off an inverter from my service van.
