Marcus's Easter Monday Adventure
difflock
Seeee,
Started 07:30, lunch at 12:00,
Took trailer up put a 1/2 load by about 13:30
Went to bring out more, decided to doze a wheen o branches off the landing.
OOPS.
Back for tow strops an odds and ends.
Recovered by 18:30, after finally switching the winch to the Ould DB.
Only need single line pull on about a 1/2 drum.
Strangled the tractor stone dead on the first attempt, only about 1250rpm.
A few more reves an bobs yer bent Uncle.
Cost me a drop arm with the initial sideways winch.
PS
Well seeing the wee crawler is a "Mountain" varient.
No lack of oil pressure even at that somewhat extreme angle.
I did think to check!!
Edited by difflock
No!
(i) Bigger, therefore much more cumbersome.
(ii) Heavier, therefore more likely to (a) get bogged and (b) more difficult to extricate.
(iii) On bald tyres = useless in the Moss.(though there is another school of thought on that issue)
cheers
PS
Wot I really need is a 6-8 tonne excavator on long reasonably wide steel tracks.
With grapple etc (and to double up as a recovery aid)
Plus a 10 tonne front mounted hydraulic recover winch on the crawler.
Plus explosive couplings for the ends of the link arms so as I can "blow" and discard that horrorendously effective brake otherwise known as a forestry winch.
cheers
m
